JUST COMPLETED-ZERO MILES-ALL NEW COMPONENTS-READY FOR STREET/TRACK USE
*ACTIVE POWER ZSR space-frame chassis GT Reproductions
-Chevrolet Z06 suspension components/brake calipers/rotors
-QA1 coil-over adjustable shocks
-ZR1 rims 17x8.5 front and 17x11 rear
-ZR rated tires 315/35ZR17 rear and 245/40ZR17 front
*Ultra heavy-duty GT40 fiberglass body [at least twice the thickness/strength of others
I have seen in the U.S.]
-original spec stainless door handles/latches, locking fuel caps, headlights, side windows,
headlight covers, body latches
-DOT glass windshields, BOTH front AND rear
-Aero-Catch rear hatch latches
-Interior panels coated with LIZARD SKIN
-Double rear fire wall
-Full belly pan
-All interior/exterior panels are fastened with RIV-NUTS for easy removal
*All NEW 306 ci small block Ford engine built by Doug's Speed Shop in Binghamton,NY.
-Fully prepped 302 block bored .010 over
-Nodular iron crank, scat rods and forged pistons
-Champ-Pans road race
oil pan
-Edelbrock Performer RPM aluminum heads and intake manifold
-stainless steel rocker arms
-chrome 100 amp alternator
-MSD ready to run distributor
-Meziere electric remote water pump
-Edelbrock 600 cfm carburator
-All Russel/Earl's fittings/lines
-Custom aluminum racing radiator and cooling fans
*Audi 016 5-speed gear box with Quaiffe LSD prepared by Jerry Jansing at All-Pro Cars
-Kennedy engineering adapter plate
-Stage 3 clutch
-Branwood cable shifter
-Rear drive axles from Tha Drive Shaft Shop, Salsbury, NC
*Stainless steel full cross-over exhaust from Stainless Works, Cleveland,OH
*Race-Tech Saker layback seats-both driver and passenger. Seats are fully FIA approved.
-IMPACT by Bill Sipmson 5 point racing harnesses, both driver and passenger.
-MOMO steering wheel
-Wilwood dual mastyer cylinder racing brake pedal and single master cylinder clutch pedal
-hydraulic throttle pedal
-VDO guages
-aircraft quality dash switches/lights
*Show quality paint/body work with well-over 200 hours in body prep/allignment
This cas was assembled with great pride in upstate NY at my small hot-rod shop. we have extensive experience in preparation of both race and show cars.I have worked closely with Chris Arden on the developement of the ZSR chassis and we are thrilled with the results. The buyer will have a fine example of a GT40 replica with a modern suspension geometry.
Price is $54,900
Car is located in Vestal,NY and is available for inspection any time. Feel free to contact me at 607-621-1330 or
jdeuel87@hotmail.com
Pictures can be seen at the cars for sale section of
www.gt40s.com
