  #22 (permalink)
Old 04-09-2008, 05:20 AM
Default Thank's Mike for the info
FFRCobraMike Thanks for the info. I guess a bronze gears was a safe bet. IMO If there is an alignment problem the steel gear on the cam eats this gear up quick. The shavings will still endup in the motor on the way to the oil pan. If lucky, the filter catches the particles. I would have thought that Comp would have a recomended gear for each application. Someone said they should sell the correct gear with the retro kit. I have only run the car twice last year so I am not 100% sure that the composite gears is going to work. I do have extra oil going to this location to lube the contact spot of the two gears. This doesn't help you. Hope everything is OK with the motor now. The BBB is a waste of time and tax payers money. They don't do anything here in NJ except get paided. Fly by night construction companies with 3-4 different names. All they need is a PO box and answering machine. NJ is finally maken changes and forcing them to register with the state. Only the Illegals are complaining about this. Go Figure. Rick L.
