Thread: MSD Issue
Old 04-09-2008, 06:45 AM
Barry_R Barry_R is offline
Make sure that your 12v "key on" connection also has 12v while in the crank position. Some ignition switches may separate the two because factory points systems use a resistance bypass circuit (tied into/fed from the "I" terminal on the old Ford starter relays).
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
