  #21 (permalink)
Old 04-10-2008, 06:16 AM
ddcobra's Avatar
ddcobra ddcobra is offline
Thumbs up
Hi guys,
For the Comp Car we are using a 331 with a lot of rpm (rpm limited at 7100rpm power still climbing) still run on pump gaz (10.4 to 1) 520HP at 7100rpm and 430lb-ft at 4900rpm, tremec tranny, alu. flywheel and a 6 puck disc with Ceramic buttons allows for repeated quick shifts, alu. drive shaft, wilwood 4 piston caliper front and back,double aduj coilover, bumpsteer kit (no bumpsteer at all), fully aju. control arm front and back with 3/4 rod end ect...
Don,
