Old 04-12-2008, 09:43 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
You should be running 14+...
Move on to the next step as we spoke about on the phone...
Alternator check, then if that checks out, replace the voltage regulator...
You should still be under warrantee... Just call Tim at Dynamic....
Starter is on the passenger side, lower rear of engine...follow the other big red cable from the solenoid on the firewall we spoke of. While your there, there is also a large black cable from the starter bolt to the chassis. Be sure it is tight at both ends...
Let me know...do that before installing the new voltage regulator...call tomorrow with any other questions...
