Originally Posted by patrickt
Trick question: If you replace your stock crank with a stroker crank have you changed the relative orientation of TDC?
I don't know, but on my 331, I put the pointer in the standard,stock location and it lined up perfectly with TDC, but it also has an aftermarket performance balancer on it......not a stock OEM balancer....
David
