Old 04-16-2008, 05:54 PM
Tangible Toys Tangible Toys is offline
Cobra Make, Engine: Backdraft #520, 302 FORD racing Z50Z,t-56,391 posi
Good evening R.Smith,
in order to reverse the signal stalk,all you need to do is first loosen the 2,13 mm nuts on the u-bolt just behind the dash, that goes around the colunm,next,open the hood,about a foot down from the firewall,there is a thin bracket that the colunm goes thru,in that bracket are 2,3mm allen socket head bolts.Loosen all the fore metioned bolts and rotate the colunm clockwise to your desired postion,you can not turn just the switch because there is a tab welded on the colunm so the switch won't spin. Also will will have to turn the wheel hub 180 degrees so the signals will cancel.
To remove the hub you will need a 2 or 3 finger puller,HEAVILY TAPED AT THE WHEEL SIDE,put the puller on the lip of the wheel at the hub,and the puller bolt on the steering shaft and gently tighten the puller,the wheel and hub should loosen with a quick snap,be prepared to catch the wheel and hub.
Wayne Pontes & Mary Ann McAlinden
http://tangibletoys.com
