Old 04-17-2008, 08:44 PM
SantaFe66 SantaFe66 is offline
Cobra Make, Engine: Cardiac, 428 FE
Can't speak about the process for switching the column over to the left but can about the lever that has to be modified so it doesn't interfere with the dash. I picked up a Ford PU turn signal lever from the 60's/70's from a wrecking yard that didn't have any rust (just unscrew it). I measured to make sure it was short enough to clear my dash overhang, cut it off, and filed a flat for the knob set screw. Got the knob with the car so don't know where it came from. Do a Google search or try the ones at www.Lokar.com
I bent is slightly to clear the dash overhang and it works fine.
Paul
