04-18-2008, 03:33 PM
CA
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by Great Asp
Same thing here. You only need the top two bolts, but I recommend that you apply a couple of those heavy felt stickers (you can look in Lowes or Home Depot in the hardware section) to the back lower part of the plate, in case someone presses on it, or you slam the truck. Keeps from the plate scratching the paint.
I put some black gasket sealer on the back of the bottom bolts for this same reason. It works well...
