Ital-
Was your body made in Canada? SHAME ON THEM FOR NOT PUTTING IN THE WOOD BLOCKS! Yes, definately glue-fiberglass some wood blocks in. These are what will remove the stress of the top and window bows pulling against the fiberglass. about 2"s wide, 3"'s long and 3"s deep. Measurements are not exact but this will give you an idea. Once you have the door inside panels cut out they are pretty easy to do. The two on the rear body are the tougher ones, but they will go in, just do not glue in the rear wheel tubs until the body is being mounted and the wood blocks are installed.
DV
