Ok.. I used the piston stop and found my TDC was off by approximately 1 1/2 degrees (behind). I already set the valve lash the other week. I'd think the lash is ok even though my TDC was off a little bit.. I'll paint a thin line at the outer edge of the damper showing the more accuarate TDC position. I still think I need to put the timing tape on because the behind TDC scale is so far beyond the TDC. What do you think? Thanks.
