Old 04-21-2008, 05:13 PM
Pacco Pacco is offline
Default Replaced temp sensor...
And the gauge doesn't work. The sensor that I removed was an old school looking setup. The wire leading to the back of my gauge is approx 14 gauge and is hollow. I replaced the fan switch thinking this could be the problem with the fan not kicking off and engine not reaching the proper running temp. Replaced the sensor with one from Advance Auto, not even close to the same look as the original one taken off the car. The original had a fitting that had a brass probe around 2 inches long with the hollow wire all in one piece leading to the gauge. The wire snapped and I replaced it with the sensor from Advance. What can go wrong next? Any ideas of where to go next? Thanks!
