Thread: taillamps
Old 09-23-2001, 06:58 AM
Bill Wells Bill Wells is offline
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
yes sir, turn signal is its own bulb...run and brake lights are also a separate bulb. each bulb has its own socket obviously and housing . half of the vertical rectangle lens area is illuminated by each...so on run/brake only 1/2 of the entire lens is backlit/illuminated, same with turn only (the other half) and if braking at same time as turn sig is on , then the entire lens is illuminated. B (I can see clearly now, er, be seen clearly now)
