Miss Piggy
Latest test mule 427 SC Carbon car just corner balanced 50/50 at 2150.
Iron 428 FE w/aluminum heads, steel flywheel, ford starter, iron toploader
with hurst shifter. Original suspension. Weight is ready to go, empty tank.
Will be doing a complete flywheel/bell/clutch/trans swap shortly to see if
I can get Miss Piggy on a diet, while adding an extra gear.
(a major issue with the lighter car is the left/right balance WITH driver...)
(believe this may require a much smaller intake manifold and exercise...)
