  #48 (permalink)
Old 04-23-2008, 07:49 AM
franklin franklin is offline
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
Ross,
Can I ask a dumb question? I have one of your bellhousing it is the one for the FE and it is the one made for the toploader, even though I'll be using it with a Tremec 600 (due to the short input shaft for my Kirkham build).
My question is this: I know your bellhousings are strong enough for my application, but I was surprised to see that my bellhousing came without a cover for the starter/flywheel area and same for the clutch fork area. What is supposed to be used in these areas to make sure they are covered securely and safely in case of a clutch failure? Let me know if I should have received something or if you offer a solution for these areas.
Thank you,
Todd
