Old 04-23-2008, 03:33 PM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Water Wetter is fine...you're not putting in enough to make it slimey.
Byron...anit-freeze prohibition is SOP at all tracks. It's greasier and harder to clean up than just about anything if it gets dumped on the track. You can put some back in after the Bash. BTW, it's been mentioned several times in threads and is on the instruction sheet.
I never run it in the Cobra...water cools better, aspecially with some WW. You can use some lube additive available at Pep Boys, AutoZone, etc. for the electric pump. Years of autocrossing taught me that along time ago...hard full bore passes with five to ten minutes of idling on hot concrete for the next pass...ran my Vette and the Cobra on just water and WW, and it stayed cooler with no problemos.
Jamo
