Originally Posted by wtm442
Make sure that the linkage is not binding. Spray some penetrating oil on every joint and see what happens. You may also need a stiffer return spring.
I'm thinking linkage/gas pedal problem too.. If it's cable operated, check for frayed cable (could be hanging up internally in the housing). It's happened, with like symptoms, to me too.
Dave
