Old 04-24-2008, 05:26 AM
Default Shafts and high idle plate stuck up
ERA Chas Does this happen when the motor is hot or cold? If cold you should be able to seperate and check all the pivot points one by one. Make sure the pivot center piece is free and moving easy, If you feel any binding replace that joint. What I used for linkage lube is chain lube for a motorcycle. It's waterproof and stays where you spray it. 15 years out of this setup is a long time and you got your mileage out of it. I would next check the hiem joints on the bars for the car linkage to make sure they are free too. It could be the gas pedal pivot heim joints. After this you are looking at the carbs, the first thing to check is the choke high ilde plate and that it moves free and doesn't stick. I have had a couple of carbs with chokes,( 600, 780 ) that this plate wears on the shaft and hangs up, some times hot other times cold. If you get the car to act up, turn off the motor and pull over to the side of the road and look at what is not in the right postion on the carbs. DON'T touch anything right off, just LOOK. If you don't see anything then start to move the linkage and see if anything changes. Next would be the carbs themselves, Check shaft end play and wobble. If you are running strong return springs to the main linkage arm you will wear out the throttle shafts and base plate unless they are roller bearing. I don't think you would have this done unless racing. You would have to check to see if there is even bronze bushings the shafts ride on. If not Send out both base plates and have thing done. You will not always feel a shaft hanging up unless you move it to the stop and feel a small jump. If it is a vacuum leak coming from the motor, I have found that using a small bottle of propane with a little vacuum hose and needle point end under LOW pressure will help you fine and external leaks.If there is an external leak the motor will pick up rpm's. The intake gasket could also be split and leaken after 15 years of running. I have seen a few #1020 felpro gaskets split and leak. If you want to talk about this some more , call me 732-254-3536 in the evening est time Rick L.
