  #90 (permalink)
Old 04-24-2008, 08:58 AM
FWB's Avatar
FWB FWB is offline
Default the brakes......
Originally Posted by FWB View Post
8 inches of vacuum will not run a power booster... i installed a vacuum pump
but be careful most of the pumps out there are junk. i installed this swiss
job, it really works well maintains 18 inches of vacuum and can be run without
a vacuum canister. heres a link. ( i bought the horizontal)
www.metricmind.com/pump.htm
again,,,,i have wilwood brakes. i have 8 inches of vacuum i did not stop without
a vacuum pump. installing one that is belt driven is a pain inthe ass if you already have your engine compartment completed. the metric mind pump is designed for an electric car that produces no vacuum. this pump will provide
the complete vacuum requirements for a power booster. you will hit your face
on the steering wheel with the braking power you will have. just connect it to the booster and connect it to the power and the braking problem is solved. there is nothing wrong with your rear brakes.
Fred
