Thread: oil cooler
Old 04-25-2008, 07:01 AM
abram99768 abram99768 is offline
Cobra Make, Engine: classic roadsters II, 351W with about 400 hp
Default clearance issue
Originally Posted by bobcowan View Post
Unless you're going to run lopen track events, don't bother. When I'm not on the track, I have to keep mine covered or the oil never gets much above 150*.
I prefer to use a sandwich type thermostat, and keep the filter in the stock location. That keeps your oil connections to a minimum.
I wouldn't use anything but AN lines and fittings for any external oil conenctions.
Thanks bobcowan.
I agree with you as far as keeping less connection. Not only that, but a cleaner look. My only problem is do I have enough clearance from the engine block and the frame to fit that sandwich plate and the filter.
If you had done that in yours you will know.
I have a 351w and have just about 5.5-6 inchase of clearance.
