Charlie
You probably found the problem already, and the guy's gave excellent suggestions. I have run across a multi carb with a similar problem, the main linkage spring would close the front carb throttle plate. The rear carb after the linkage released tention was dependent on the holley incorporated throttle spring. The spring was not strong enough (for what ever reason) and would not close the throttle plate to the fully closed position...
Tony
