Thread: Differentials
Old 09-24-2001, 05:57 AM
ozracer ozracer is offline
Default The Diff Saga
Mike thanks for the reply on both posts. Yeh on the surface Ian's kits appear to be superbly engineered and good quality. i intend popping over thie in the next two moths to check them out and have a squiz. In relation to the diff what did you end up doing with rear and front sway bars and did you utilise the discs and callipers from the rear end or did you use Wilwoods on the rear as well. I assume you have used the hubs as well and the upper and lower control arms which attach to mounting points on the chaiss from this diff. Or are they all manufactured by Ian as well?
