Problem is how do you tell if your pedal is going too far? I could understand if the clutch pedal went to the floor but, I don't have any pedal at all....I'm only pushing in an inch or so now and the pedal is rock hard. Even if the shifter is in Neutral it still squeals like a pig when started???
I don't think we have too much pedal travel and I rechecked the distance to the fingers on the pressure plate and the readings are dead on for what the hydraulic bearing was built for???
HELP!!!
