427 Stang is right about #3 looking bad. Looks as if it isn't getting any spark at all of a very weak one. As for the leads to #7 & #8, yes, separate them as much as possible. I use the good wire also and after dark with them just separated by the plastic spacer I have seen them cross over once in a while, so I put them two spaces apart. Remember the high ignition voltages are more prone to do this than a stock one was.
