The Triumph wipers can be cut down or extended as desired. You are only limited by the length of the inner cable and that can be cut short as needed. More important is the diameter of the gear in the wheelhouses and the location of the drive pin in the motor head--that will determine the arc you get on the wiper on the glass.
John
