Old 04-28-2008, 07:02 AM
Andrew429's Avatar
Andrew429 Andrew429 is offline
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Default Heat Insulation Paint
I'm chasing ideas for paint-on heat insulation (something ceramic would be nice). It would be applied to the inside top of the front wheel arches to prevent the panels from overheating and pulling. (Live sidepipes appear to be causing other kits similar to mine to cure a bit more in the tops of the arches).
Here's the catch,... I'd rather apply it with a brush than a spray gun, as the engine install is 90% complete and I have installed powder-coated aluminium cladding around the rest of the engine bay (masking and access would not be easy) .
I have done a bit of reading into Lizard Skin, but it looks as though this stuff really has to be sprayed on.
Any suggestions gladly welcomed.
Andrew
