Old 04-28-2008, 05:39 PM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
Brent,
Yea a crack would suck! lol.
I’m building an all Aluminum 565. I got deal on a new A96 block with 351 mains (Unused pro-stock block) so that forced me into a custom crank.
the plan is:
4.250 stroke
4.600 bore
6.800 rod
11.7-1 JE pistons (custom with a spherical dish)
Fully Ported SCJB heads (avg. 382 cfm @ .550)
Solid roller
Danny Bee belt drive
5 stage Aviaid dry sump
Reverse flow cooling with electric pumps
Kinslers new SCJ EFI manifold with 3" throttle bores
Just today I was trying to work up the cam specs with Lem Evans. And it seems that the valve and spring package that comes on these heads is very near coil bind, when you use the cam that Ford recommends. (much smaller than I need to run) So I’m going to return the heads to Lem and swap all the intake valves for 2.250dia (from 2.200) with a +.100 long stem, bigger springs, Ti retainers, new valve job, re-port for the new valves. There goes another $1000.00
It’s designed to be a max effort, pump gas deal. I’m hoping it will make 850+ hp. It may be optimistic, but what the heck!
In a 2600 lbs car with 325 drag radial, it should feel pretty fast….. for a little while.
What’s you 547 gonna look like?
