04-30-2008, 01:54 PM
Club Cobra Member
Fra
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
Originally Posted by RICK LAKE
BOURRAT If you have to have this manifold for your car, Get it flow balanced for all the ports. Joe craine does a great job at this. If you need metal added to the bottom for more port surface, he can do this. It may not flow like a single plane BT manifold but the ports will be bigger and within 5% of each other. The cool thing is you can't is the magic work he does, but will feel it in the car. He is on the FE forum. Has done 40+ manifolds for the FE forum guys alone. Very good price and his work is beautiful. I would guess at a 20-40 cfm per port with some modes to the carb mounting area. If you want an e-mail address I will get it for you unless some one here aready has it. Rick L.
OK: look at your P.M. (personal messages)
Queenie
