Old 05-03-2008, 06:00 AM
Rob. Smith Rob. Smith is offline
Sambo, I think the stuff you're looking for is called "spagetti". It's just a plastic sleeving.
There's another stuff called spiral wrap. It wraps tightly around your harness bundles but allows branch wires to exit where ever you like. It looks good too. It won't keep dirt or water out. I used it under the dash etc. Got it from Jaycar. Heat shrink is mostly used to seal up crimped connectors to the wire. It provides a semi rigid support to the wire where it enters the crimp.
Try electrical distributors like davis & spence, laurence & hansen, rovert, Farnell is real good on electronic bits and rs online is good for most electrical stuff...a bit pricey though.
Smithy
