  #46 (permalink)
Old 05-03-2008, 08:36 AM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
Originally Posted by jhv48 View Post
I bet it's a timing issue.
Check your initial setting first.
Then check to see if you are getting full advance at WOT.
I've checked the timing and the advance and both are as they should be.
Resetting the float levels hasn't fixed it either.
I'm running out of things to check. I've just changed the spring in the vacuum secondaries for a lighter one, but I don't really expect that to make big difference.
Paul
