Old 05-03-2008, 07:07 PM
dlampe's Avatar
dlampe dlampe is offline
I would probably stick to a street tire with a tread wear of 200 or higher. That will put you in the street class. If you have a lot of track experience then run the Hoosier R6's but that will bump you up to the prepared group. I strongly disagree with Bill about the safety of the street class tires. These tires will squeal before they let go. If you take that as a warning to slow down a little you will be fine. Soft compound race tires work really well until they don't, then you are gone! There is very little grey area with race tires.
High Maintenance Racing Team
Run & Gun 2003 - 2013
