I need some help from the experts
. I am down to hooking up my MSD 6AL box to my ford duraspark distributer. Here is the problem I have. I hooked up the box per the instructions. When I turn the key to the run position I am not getting any power to the coil. When I crank it over the coil shows power (test light blinks). I then took my test light and checked the battery side of the starter solonoid and it blew the fuse in my test light???? I had done this before I hooked up my MSD box and had no problems. when I touched the battery side of the starter solonoid.
The ground wire is hooked up to the same ground I used for my starter solonoid. This is the only thing that is keeping me from starting up the cobra. Also I am using the painless wiring harness.
Thanks in advance
Ray
