Old 09-25-2001, 04:28 PM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Jim - your voltmeter readings do not look too far out. if you have a good meter, check the voltage across the battery with about 2000 rpm on, i.e. full charge - should be 14.3 volts. This will drop back a couple of volts when you turn the engine off.
Car instruments not exactly accurate anyway.
HTH
Wilf
