Old 05-10-2008, 02:22 AM
Default Not that much differents Ron
Ronbo with some of the great carbs on the market now and a good carb tech, your FI system will be about 5-8 hp less that a carb. This is under dyno room conditions. With the FI system are are getting the best drivibility over all. The other thing is you can get a carb in up to 1,400 cfm's of flow. Most FI systems run a 1,200 cfm throttle body. This is great for street driving but gives away big time to high rpm racing. The TWM setup will beat a carb up to maybe 5,600 rpm after this the carb starts to catch up and pass. Rick L
