ddcobra If money is no problem,? What tracks are you looking to run at? I run a G-Force, custom gear setup. 5th gear is 1-1. You may want to look at the richmond superstreet. It's a 2.87 first gear with overdrive 5th gear. What rearend ratio are you running. You are asking for a ton of info. Send me a private e-mail with time and place to talk to you. Rick Lake Ps what's the HP and torque on your motor? There are 6 trans missions that will work. T-56 with blueprint update, G-Force semi clutchless, TKO 600, Richmond superduty 5 speed. Richmond street 6 spd. Need more info from you. Again it not that simple.
 Sorry didn't know you where out of country, send e-mail to your home address, not going through CC
