OK,
Maybe I am reading this wrong but a "bus bar" or grounding strip is convienant and easdy to use but most of them , unless each opposing screw/lug is grouned seperately it is nothing more than stacking one ground onto another-just neater and for the most part will probably work, BUT these are NOT dedicated type grounds seperating one electronic device from another. If you have hi-tech electronic equipemtn, i.e.; MSD, Amp(s), electronic speedo, electronic
oil pressure, etc. please make sure they have seperate dedicated grounds.
DV
