Old 05-13-2008, 09:45 AM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
I know its late in the game however this is the list I am working off of:
Figure most will read this thread. Brent just let us know if you need any help when you get to the BASH.
Track Prep:
x□ Check oil / replace
x□ Drain coolant and replace with water
x□ Inspect seat belts
x□ Check lights (head lights and tail lights)
x□ Instrument lights
□ Shift Light program
x□ Replace brake fluid
x□ Replace clutch fluid
x□ Check clutch adjustment
x□ Inspect brake pads
x□ Check shifter adjustment and set screws
x□ Inspect tires for condition and pressure
x□ Inspect Suspension bolts
x□ Check motor mounts and trans mounts
x□ Install numbers
x□ Tape headlights
□ Install screen over radiator and oil cooler
□ Hook up vent blower
x□ Buy race gas 110 octane
x□ Brake Fluid
Trailer Prep:
□ Inspect tires and check pressure
X□ Install electric wench
□ Install anti sway/load stabilizing hitch
□ Install Interior lights
□ Inspect brakes
□ Check exterior lights
Tow Rig
□ Check oil
□ check lights
□ coolant level
□ chargers for cell phone
□ I-Pod
Morgan LeBlanc
Fresno CA
