Thread: Brake power
Old 09-26-2001, 12:50 PM
Dominik's Avatar
Dominik Dominik is offline
RaceDeck,
I wish I had a solution for the front brakes via the internet.
You may check the following:
front axle settings (camber)
rotor out of round.
if one is warped (the left one) the brake piston moves farther away from the rotor than on the right side, causing a little lag.
shock absorbers.
if one is worn it does not follow the road surfaceas as the other one
(or set incorrectly)
does this make sense?
brake bias:
take your car on a slippery (wet) surface and brake with empty tank.
you do not want the rears to lock before the fronts do.
there is a drawback: due to the weight shift when braking under dry conditions the rears tend to lock even earlier. the weight shift is less on wet roads.
but i used this method as a good start. real values can be determined on a barke test station (do not know the correct expression in english).
does this help?
dominik
If I don't respond anymore, that's because I can't log in
