Old 05-18-2008, 04:51 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
The master cylinders most often can be rebuilt but at a cost of 41% of a new replacement ...? Many are made of aluminum and the bore becomes pitted from the moisture/water absorbed by the fluid. If pitted honing the bore for proper seal fit is more difficult but it can be done in most cases.
Making a short steel line for each old rubber line may reduce the diameter enough to stop interference with the pedals as a guess??? Can you get to area well enough to fab steel lines past the problem area, you mentioned re-routing was not an option? You will find a fix I am sure.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
