Outside the Footbox
Dan, the later 731+ cars route these lines from the reservoir along the top of the frame rail and then just at the front of the footbox, they make a 90 deg turn and then another 90 deg turn into the front of the clutch/brake box. They do not go inside the footbox at all. If you want a pic, I will take one for you. But the lines are steel, changing to rubber hose just at the ends.
Good thing they are steel, because they pass about 1" from a header! I don't know if this will ever be an issue, but I wonder ...
Sam
