OK,
Right where the top bow splits, look inside the channel on both sides. You will see a flat headed pin on both right and left sides where it splits. These pins, called left and right will slide into the very top middle of the windshield frame. Slide one in and pull it out ward a couple of inches, this will allow you to then put the other pin in place. Now pull the top even and hook up the side latches, Make sure you get them tight when buckeled!
Hope this helps..
DV
