Old 05-20-2008, 05:31 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Ed,
Weve taken care of everything via e-mail or phone. Thought I would bring you up to date on the frame, etc.,
Firewall is finshed off, totally sanded past the wet sand-next in about 15 minutes will be paint. Door brackets have been cut out of the cowl, ground down and ready to install when the body and doors arrive. Radiator hoop is in. Cowl bar is bolted and welded in with three "Dedicated" 1/4x20 ground lugs welded in place. Inner caps on the front towers have been cut out in anticipation of Terrys QA-1's and his super front suspension arriving. I will paint all the brackets, pedal box, hinges etc, today and install tomnorrow.
Moving right along.....Lots of pictures taken!
DV
