Originally Posted by Double Venom
Ed,
Everything is OK- But one important question? Mechanical fuel pump or electric? If it's electric I'll need it and weld a plate to the rear frame member. Makes for a very neat set up.
Might need some more fittings but I can get them here if electrical.
DV
I'm setup for a mechanical pump. Should work OK. If you need more of the black AN fittings to run the fuel line, let me know and I'll get the from Summit. I know we are going to need some of those for the trans cooler and the remote
oil lines.
Ed
