I think Don hit it on the head. All panels need to fit perfectly so the gaps are correct and the stripe is correct when all is installed. If you do any bodywork yourself make sure the products are top notch and proper prep so they do not shrink or come loose etc.. If you need to trim around pipes or what ever it is much easier at this stage than after painted and have to re-seal the edges.
