Thread: Brake power
Old 09-27-2001, 08:36 AM
Dominik's Avatar
Dominik Dominik is offline
Thanks Bob!
Where is a picture this time?
RaceDeck,
where is your switch? If it sits at the pedal it may not be gapped correctly.
The warped rotor is just a theory. You'll feel a pulsing signal during braking.
How accurately did you bleed the brakes? Any leaks after driving?
If ti was an old car I would check for stuck brake pistons or clogged linings.
While you are checking the axle settings check for worn parts as well. Now, that should keep you busy for the weekend.
Post your findings. Good luck,
Dominik
If I don't respond anymore, that's because I can't log in
