  #270 (permalink)
Old 05-26-2008, 12:44 PM
fasterpatrick's Avatar
fasterpatrick fasterpatrick is offline
Cobra Make, Engine: scratch build self design 4.6l DOHC
Default Help need more affermation!
Have been in a slump lately and could use some encouragement that everything will workout just fine. Put the body back on the frame and wouldn't you know the door frames wouldn't fit. So after cutting out the door jams that I had done last fall I made molds in the car and glassed up some new ones.
Then back to the doors now with new jams the door frames had to be adjusted to fit again (just modified the pin catches for more clearance). Finally after getting the door frames to work smoothly again, I could make some tabs for glassing the door skins to. Now to get up the nerve to start fixing the skins to the frames.
Man this is taking way longer than I thought; Patrick
