  #7204 (permalink)
Old 05-27-2008, 07:37 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Originally Posted by 4RE KLR View Post
Joe,
The freezing up is also caused from low freon. Yo may have been low on freon last year but had enough that the system would still run. But this year it shut down. Think low oil shut down on your engine. Sorta works the same way. Two pounds of freon is all that system will hold so you basically had none. I assure you that if you don't get a leak test done and the problem fixed you will have to go through this next year. You have to fix the problem not put a band aid on it.
I know I am not looking forward to 100* today. Texas is too damn hot in the summer.
After the leak test,there is at least a couple of things left to do.
The freon that was lost was replaced by air.The system needs to be pulled down (evacuated) by vacuum to remove the air & moisture .After replacing the receiver/dryer and after fixing the leak.
Like Steve said,you just got a band aid slapped on it.
