Originally Posted by Excaliber
If clearance is a problem for a impact wrench, or not, how you gonna get the pulley off after the nut is out? You will still need clearance for a 'puller' and for the pulley itself.
Clearance should not be an issue:
I pulled the
oil filter and the centerline of the crankshaft goes
below the front crossmember by at least 3-4 inches. Should be okay.
How can I tell if I have a standard or reverse flow water pump? I'm going to change that out while I have it all apart (for insurance if nothing else).
