Originally Posted by Jerry Clayton
If you don't have an impact wrench you can disconnect the coil, put a socket on the bolt head, brace the breaker bar against the lower frame rail and bump the starter---it will screw the bolt loose-----
Worked like a charm! In 4.5 years of ownership, it was also the first time my wife ever touched the ignition keys.
Thanks!
-Dean
