  #27 (permalink)
Old 05-29-2008, 10:49 AM
patrickt patrickt is offline
Leaking from the remote cans onto the frame then traveling down to the floor.
That's close enough. The leak was coming from the rubber hose that connects the remote reservoirs to the steel lines. The drip trailed down the steel lines until it hit the frame and box area where it dropped. You couldn't even see the damn leak. I found it by wrapping the lines with paper towels right below the reservoirs -- solved it by replacing the faulty "pinch" clip with an old fashioned screw clamp. See below:
